• Colin & Valerie Bugler
    28 July 2022 at 16:17 #57589
    Hi, A problem with my Starter Bendix. It keeps sticking in, so I have to get under and free it back.
    I can not find any grease point or other lub. place.
    Do I need to replace a part if so what?
    D C W Humphreys
    31 July 2022 at 22:31 #57602
    Hi Michael,
    Apologies if you have already tried…. but if you put “Bendix” into the forum search engine, there is a post by PeterS30 from April 2020, which you might find useful.
    8 August 2022 at 12:04 #57731
    Hi DCW,
    Yes, I have seen PeterS30’s post and have printed it off.
    However, it does not answer my problem, is a part worn and needs replacing or is it something I have to live with?
    11 August 2022 at 09:11 #57792
    Have you tried removing the starter motor and cleaning everything? I had my starter off last winter and I am pretty certain that there is no lubrication necessary.
    16 August 2022 at 16:13 #57831
    Hi Richard,
    I will remove it over the winter to see if it improves it.
