• Cameron Hathorn
    25 July 2024 at 17:28 #70806
    Good Afternoon,
    I am in a spot of bother and was looking for some knowledge, advice, spare parts, or possibly all three.  My Lagonda Rapier Special had a bit of a hiccup.  My oil pump failed at speed and by the time I pulled off the road some damage had been done. Luckily it wasn’t catastrophic, however the end result will require the car to have new connecting rod bearings as they were worn down significantly.  Attached are pictures of the bearings with numbering.  What I need help with is the following:
    1. Can someone identify if these are OEM, adapted, or fabricated connecting rod bearings?
    2. Does anyone have spares?
    3. Can someone in the know please point me in the direction of someone who could be of help?
    Thank you kindly,
    Cameron H.
