• DavidLG45
    1 April 2009 at 12:20 #47542
    Does anyone have any photos of the underside of the rear seat squab, frame etc of a LG45 as I suspect mine is not original. LG6/V12 may be similar?
    David Eldred
    25 April 2009 at 18:45 #47549
    Dear David,
    finally I removed the rear seat backrest and underside. I assume mine is not original either. The underside of the rear seat is covered with black cloth, so you can?t see in but at one corner it was a bit loose and I could find foam rubber cushions inside. The rear seat backrest is shown in the other photo, it has rubber foam inside too (no springs in both).
    When I had the seat away I checked the filling of the shock absorbers, one was quite low, so it was worth taking the photos
    28 April 2009 at 11:55 #47552
    Peter,
    Many thanks for taking the pictures.
    11 April 2016 at 19:06 #51859
    Last year I had to replace the rear seat plywood back on my LG45 de Ville. The seat is original but the back had suffered badly from woodworm!
    I can confirm that it also had a foam rubber interior. I believe it is called Sorbo rubber and I guess Lagonda were ‘early adopters’
    12 April 2016 at 13:04 #51860
    My V12 certainly has rubber in the front seat squabs; and very comfortable they are too. Pretty certain that is how they left the factory.
