• SRD
    2 July 2015 at 08:27 #51325
    Here is possibly the only picture of this car, which has been kindly forwarded to me.
    Year is 1952 and the location was during Mille Miglia
    Lets see how quickly the car is identified…
    2 July 2015 at 14:21 #51327
    Hi Simon,
    I think this is one of the handful of V12 cars assembled after the war. Seaton’s book shows the picture of a two door coupe by H.J. Mulliner on page 258. I have not seen a four door version before. I wonder if I am right?
    2 July 2015 at 16:29 #51328
    Colin hi
    Good guess, but not correct, this car was unique, a shame it has not survived.
    Kind regards
    Simon
    5 July 2015 at 19:23 #51331
    An earlier picture of the same car ca. 1950-51, with split front windscreen, interesting transporter and a well known make of sports racing car next to it…..
    6 July 2015 at 10:11 #51332
    This one has the registration number beginning with XMC 43 which makes it Middlesex (ie Feltham) registered around 1951 so I assume it was the 3 litre factory development prototype.
    6 July 2015 at 19:38 #51333
    Colin hi,
    Good to see someone serious about his Lagondas. Not the prettiest of cars, looks more like a barge to me…
    Getting warmer, date of manufacture is ca. 1949/50, and probably ran around on trade plates for awhile.
    Engine size was always the 2.6 litre.
    A pair of cars made, one as a saloon and the other as a dhc, the later has survived.
    Simon
    7 July 2015 at 22:05 #51336
    Definitely a barge, and probably a gutless wonder to boot!
    I suspect that someone like Jack the Breaker on the North Circular Road near Staples Corner probably cut it up with his torch around 1963!
    A friend of mine bought a type 57 Bugatti from Jack around this time – and quickly resold it when he discovered water in the oil!
    8 July 2015 at 18:32 #51337
    Colin hi
    This is the red-monster, DP113, based on a 2.6 litre chassis, see
    http://www.db-lagonda.com/dp113-red-monster/4585169701
    The works chopped it I believe, no doubt run into the ground as a company hack !
    Simon
    9 July 2015 at 08:46 #51338
    Ok, the plot thickens. Here is my speculation. As previously mentioned, one of the last few V12s assembled after the war was clothed in a very modern looking two door coupe by H.J. Mulliner. They were based in Chiswick – only a few miles from Feltham and Staines. Perhaps the ?Red Monster? was an experimental project with Mulliner to see what could be done with post-war chassis. Certainly it is somewhat reminiscent of a Bentley Flying Spur but I am sure the 2.6 litre LB6 engine would have to work really hard to drag this barge around.
    10 July 2015 at 16:58 #51345
    Colin hi
    Do you have any pictures of this V12 by Mulliner please, I suspect that you are on the right track and would be delighted to know more please !
    As far as barges go, you are you correct the LB6 engine would have struggled especially in early 1949 format, with that heavy bodywork.
    Simon
    10 July 2015 at 17:56 #51346
    Hi Simon,
    Here you go. Take a look at http://www.lagondaforum.com/showtopic.php?id=247&q=mulliner.
    It would be interesting to hear other comments on this speculation.
