• John Hugh
    15 December 2009 at 22:54 #47672
    Has anyone had experience of the wedges which are sold to, presumably, increase the castor angle of the front axle? I would have thought them likely to make the steering, already heavy, much worse. Is there an optimum angle that Staines never found?
    John
    oakley
    16 December 2009 at 18:31 #47674
    What is the reason why you wish to increase the castor angle of the front axle?
    John Hugh
    1 January 2010 at 15:43 #47688
    Hello Oakley! Sorry about the delay in replying, Christmas has seen me away from my computer. The reason for my query was simple – I’ve been told that the wedges sold by some of our suppliers can considerably improve the car’s handling – which sounds like good news that I would like to confirm, being a cynical old git myself.
    All the best for 2010
    4 January 2010 at 08:07 #47689
    Hi Folks,
    Setting the castor angle helps the handling of a car by increasing or decreasing the self-centring action of the steering. Too little castor angle and you are continually correcting the steering, too much and you will have to fight the tendency of the car to continue in a straight line when you go round bends. Both can be exhausting.
    With a well-set up vintage car, the steering is direct and intuitive – just like riding a motor bike – and just a little pressure on one side of the wheel will take you where you want to go and the castor will correct the line when you take the pressure off. Lovely!
    I once owned a 1948 Triumph Roadster and it was a NASTY car to drive – it wandered al over the road – many 1950’s cars with independent front suspension were the same. The geometry design was wrong.
    When I went from the Triumph to driving vintage cars I was amazed how nice they were to drive in comparison, with the HC 2 Litre being one of the best!
    So why are wedges needed? Vintage cars usually have beam front axles and cart springs, and over the years the springs can settle. The general view is that the springs should be flat and parallel to the road in the centre. However newly set up springs may not be so flat and this can change the handling characteristics. Another reason might be minor accident damage or misalignment. Wedges are needed to correct the castor angle in both cases. It is trial and error.
    I once drove a 2 Litre which was not very nice to drive though I never got a chance to fiddle with wedges and castor angles and have subsequently lost track of the car.
    The other fun-to-drive Lagonda (when the castor is properly set up) – is of course the Rapier, where ‘tidy’ cornering involves just the right pressure on the spokes of the steering wheel plus a dab on the clutch at the right time to change gear with the preselector box so the wonderful engine can rev and pull you round the corner….
    So its all down to wedges…
    John Hugh
    4 January 2010 at 17:58 #47690
    Thanks Colin. But does anyone know the optimum angle? Or is it purely up to driver preference?
    Guest
    7 July 2010 at 16:33 #47837
    Dear John,
    Belatedly, but how did you get on in your quest for info on wedges. Who supplies them? Did you get a response re optimum angle? Have you used them and with what result? I am in the same position as you when you first posted this topic.
    regards
    Don Courtney (C6)
    22 July 2010 at 21:29 #47841
    To get the right angle, I think it is similar to going to to an optician for an eye test using the special glasses.
    I fear that you will need a section of wedges which you then try in different combinations to establish the correct castor angle in relation to how your springs are set up. Presumably, once a suitable combination of wedges has been found the best, one would have a set made to this specific angle.
    I can’t see any other way of doing. Can anyone advise me to the contrary?
    Guest
    23 July 2010 at 10:52 #47842
    Dear Colin,
    Thanks for taking the time to respond. I notice from your earlier response to H54 that you said then “trial and error”. So that is what I shall do but in my usual ham-fisted way I suspect there will be a lot of error before I get there.
    Lying on the garage floor messing about with heavy bits loses its appeal once one passes 70. But then visits to the optician don’t have much appeal either.
    Yrs
    Don Courtney
    23 July 2010 at 17:11 #47844
    Dear Don,
    without having practical experience with adjustment of castor angle, some thoughts:
    1) you can do it the try and error way, which makes sure you have optimised it for your car (depending on all the other angles in axle geometry). The effects of increased positive castor angle are described in books or wikipedia (more castor angle runs more straight and gives heavier steering)
    2) you find the correct value in documents, (Arnold Davey?, if you find such information please post it here for others) have your cars castor angle measured (with a do-it-yourself measurement device or done by professionals), than you have the difference and can get a suitable wedge to put in
    3) you find the same type of car that performs well (test a car from a club member who thinks it is perfect) and if you agree, have it measured, than have your car measured, this gives you the difference needed
    24 July 2010 at 08:36 #47846
    Following Peter?s helpful suggestions, may I add some more thoughts?
    I put ?inclinometer? into eBay and it returned some great items for our needs. For example take a look at the Wixey digital angle gauge/inclinometer, item number 230498995472. Even more sophisticated is item 390219646848 called the ?SlopeView? which includes a laser, though it is fairly expensive. These look like the right tools for measuring the castor angle of cars that handle well, and then comparing them with figures for a car that does not. This gives an absolute value which eliminates differences in the ?set? of the springs.
    There is a YouTube video of the simple Wixey device at http://www.youtube.com/watch?v=yhweDL3DiYM
    I love clever tools and I?m tempted to buy something like this Wixey unit and try it out. Any one else got any thoughts?
    28 July 2010 at 20:47 #47850
    I bought one of these Wixey digital angle gauges, which arrived today. It?s a neat unit. I tried it on my 16/80 which has long wings so the flat bracket used to support the cycle wing brackets seems the ideal place to put the gauge. I set it to zero in the ground and then obtained a reading of 3 degrees castor so this might be the right figure. This car is a delight to drive, with light, precise steering.
    A word of caution. I currently have the engine out so this measurement may change after it goes back in. When I get a chance I will measure the castor angle on some more cars and report back.
    Great tool. Maybe my shelves will now be level as well.
    Guest
    30 July 2010 at 11:41 #47851
    Thank you Colin. That seems worth a try. Have recently had the axle off as the new club kp’s fell through the worn axle eye. (I exagerate a little but there was 30 thou difference. Re bushed and all going back together at the moment. Have fitted a couple of wedges(folded-over metal strips) which David Ayre gave me some while back. Will report in due course but I envy your enthusastic description of your steering.
    Don
    1 August 2010 at 11:38 #47853
    Hi Folks,
    Here is an update on measuring castor angle using the Wixey inclinometer. It seems to be around 5.9 degrees on my 2 Litre. This car handles pretty well and the steering is not heavy. This reading is possibly more reliable than the one I posted for my 16/80. This because because it has the engine out at the moment, so most of the weight is off the springs.
    The Wixey unit is so precise that it seems to indicate slightly more castor angle on one side than the other by about 0.2 of a degree!
    My 2 Litre is a a high chassis version and the unit sits very conveniently on the spring pads.
    John Hugh
    27 August 2010 at 23:58 #47881
    For Don Courtney – my apologies for failing to reply to your post, I’ve not visited the forum for some time being preoccupied with moving house etc etc… I got my wedges for not a lot of money from LMB but have yet to play with them so can’t comment on their value I’m afraid. If anyone does have the castor angle of a well-steering HC, it would be good to know it.
    John
    Guest
    2 September 2010 at 16:57 #47887
    Thanks John,
    Have also been away hence short delay in acknowledging. An engineering chum (replica steam engines) in the village is going to make some up for me. Have bought a Wixey – very good, and will report in due course.
    Don
Viewing 15 posts - 1 through 15 (of 16 total)
