    25 September 2012 at 11:46 #49664
    Which grease should I use for the two driveshafts?
    25 September 2012 at 14:10 #49666
    You might want to consult others but my recollection is high graphite content for extreme pressure applications; it’s almost black in colour
    25 September 2012 at 14:25 #49667
    Graphite grease is recommended for splined applications, I am wondering about Moly Grease too…
    25 September 2012 at 15:13 #49668
    In the beginning, AML chose an “ordinary” grease but after repeated half-shaft failures under warranty they got in Hardy-Spicer for a design review, who immediatley spotted that the designed geometry of the shafts was not perpendicular to the plane of wheel rotation, which causes uneven peak loading on the splines which the “ordinary” grease couldn’t cope with. Hence the change to graphite grease. Your call re Moly grease though
    25 September 2012 at 15:39 #49669
    I think Hardy Spicer knew their stuff, so graphite grease it is. I had to replace one of the Hardy Spicer UJ’s, both outer ones have now been replaced. The splines don’t appear to have any play (though both shafts have been replaced) – the UJ’s may have taken the peak loading and saved the splines?
    25 September 2012 at 16:33 #49670
    It also occurs to me that when re-assembling each half-shaft it is important to align the splines so that the UJ yokes at each end are parallel to each other (and not “out” by one or more splines)
    Alec Rivers-Bowerman
    25 September 2012 at 22:34 #49672
    If your input and output shafts are more or less parallel to each other, but move laterally with respect to each other, the best setup is to have the yokes on either end of the shaft parallel to each other, not at right angles. U-joints are not perfect when running at an angle, and although the diff may be running at a steady speed, the driveshaft will vary in speed. By aligning the yokes on the shaft in parallel this effect cancels out and the wheel should run at a steady speed.
    Alec
    26 September 2012 at 08:49 #49673
    Alec is right, have edited my previous
    ray sherratt
    28 September 2012 at 09:42 #49681
    Re- spline & joint lubrication.
    A 140 grade oil is recomended for joints and splines,sliding joints
    ( not splined ) on agricultural shafts a graphite-based grease
    is recommended. Data from Hardy Spicer Ltd published in
    servicing guide to british motor vehicles volume 3. When a grease
    gun is mentioned on a service sheet, it is only a macanical means
    of delivering the oil.
    Ray Sherratt.
    28 September 2012 at 09:48 #49682
    Oil is not suitable for LR drive shaft splines for reasons I set out earlier
    ray sherratt
    28 September 2012 at 19:06 #49684
    David.
    The information was for general use and not Specific. Indeed the use of a graphite or Moly
    base lube has increased the life of componants immensely. I thought it may be usfull to other
    Lagonda users. I am not questioning your knowledge in any way shape or form. Rocol make a superb
    dry Moly assembly lube.
    Ray Sherratt.
