• John Hugh
    14 October 2013 at 19:12 #50474
    I have had my 14/60 for several years with no significant problems. More recently I had the engine professionally rebuilt since when (and I don’t imply any connection) I have had two rocker pins fail about 50 miles apart. Whilst the rockers were replaced during the rebuild, the pins are original.
    In my understanding, pin failures are rare (more so than rocker failures which themselves are uncommon) and I think that these failures cannot be just random and coincidental. Has anyone had a similar experience? All bright ideas will be much appreciated.
    John
    Mike Fountain
    22 October 2013 at 10:48 #50483
    Hi John, I had a series of pin and rockers fail a few years ago following the fitting of my new semi downdraft head. The problem was finally traced to a valve guide not fully pressed home. Although when I replaced the broken item I set the correct clearance when the engine heated up the rocker hit the top of the valve guide and then either the pin or rocker broke! As I was on a rally in France at the time I did not fully investigate until I came home. Is it the same rocker/pin failing? Have you had the valve guides changed? I would suggest you check the clearence between the top of the guide and rocker.When I finally found the cause of the problem I took about 20th from the top of each guide.
    John Hugh
    22 October 2013 at 14:25 #50484
    Thanks very much for this Mike. Yes, the guides have been replaced and also the camshafts are high lift which would compound the sort of problem you describe. I hear no sound of touching when the engine is spun on the starter but of course a hot engine and high revs are a very different scenario. I’ll investigate as you suggest.
    Different pins failed – first #4 exhaust and then #1 exhaust.
    Mike Fountain
    22 October 2013 at 15:06 #50485
    When I had the problem it ran for some time between breakages If only I had found the cause on the Rally running with larger tappet clearances would have got me home! I guess with the new cams you are already running with at least 10thou clearance.
    ray sherratt
    22 October 2013 at 18:50 #50486
    I would suggest that you have at least .050″/.060″ between
    the top of the guide, and the top cap bottom/split collet
    bottoms at full lift. The reason for the gap is to stop oil
    being forced down the guide. Make sure the top of the guide
    isn`t flat, it needs to tapper downwards and outwards from
    the valve bore.
    Ray Sherratt.
    John Hugh
    28 October 2013 at 22:24 #50491
    Mike, Ray,
    I’ve now had a look at one of the valve assemblies and am a bit wiser. The guide is certainly OK – fully seated and a standard 2 litre guide. But I think you are right that there is inadequate clearance between the valve cap and the guide though it’s difficult to measure through the springs on full lift as the pockets are quite deeply recessed. I think I’ll try the plasticene pad ploy.
    Many thanks for the help, much appreciated,
    ray sherratt
    30 October 2013 at 19:24 #50494
    Put the valve at full lift, and arrange a suitable leaver to
    open the valve further. If you have a dial gauge and a base
    to mount it with, set the gauge on the top cap, set to zero
    and lever the valve open, take a reading. You need at least
    .050″ more. If you have a high lift cam allso check for valve
    spring coil bind.
    Ray Sherratt
    John Hugh
    1 November 2013 at 23:57 #50513
    Ray,
    No dial gauge but plasticene suggests the clearance is much less than 50 thou. At least I now understand the pin failures.
    Thanks for the help, much appreciated.
    ray sherratt
    2 November 2013 at 22:09 #50514
    Thanks John just trying to help
    Ray.
