• Peter Hewitt
    6 September 2026 at 11:07 #83831
    My M45 is not firing well on the coil side – mag side is fine!
    I’ve replaced plugs and coil but now need to look at condenser and points (the latter look OK but worth replacing).  I don’t know what distributor it is but if we assume it’s original does anyone know where to get the points and condenser please?  I can’t find them on the club website.
    I’ll also get new HT leads made as these are silicon and might be breaking down…timing was always fine and I can’t imagine it’s slipped but will be checking that too.  Thanks in advance
    Peter Hewitt
    7 September 2026 at 08:39 #83836
    Photo for info
    L C Hannam
    7 September 2026 at 10:29 #83838
    I can’t tell if your distributor is original, other than it’s circular case suggests it’s prewar. That said, the points, rotor arm and condenser are all certainly more recent manufacture.
    Your rotor arm “contact” would have had a tail, that has been cut off. Rotor arms where the “contact” is fixed by a brass rivet are known to be suspect, so I would certainly replace that. Especially if it is made by PARK …. my LG6 got through two of those very quickly, burnt right through. The condenser again is a modern replacement. You need to be very careful buying ignition parts such as these, coil, and distributor cap. Much of what is currently sold, even if Lucas branded, is very poor quality and prone to (very) premature failure. You are better off buying genuine NOS items, or even proven working used (my LG6 was running happily on its original genuine Lucas rotor arm after the PARK joke items). Otherwise, buy from “Distributor Doctor”, who only sells proven quality components.
    The points are commonly available, Lucas 420197, DSB116, DSB116C. If you’re going to this year’s AG, I have a spare NOS set you can have for half the going rate, say £7. Let me know if interested and I’ll bring them with me.
    T J Mann
    7 September 2026 at 12:52 #83843
    I had problems with this original  Rotax set up  after I put an alternator running off the prop shaft.  Lucas make various parts that fit.  However the condenser is ofter overlooked until everything else has been changed. The higher voltage from an alternator produces an arc across the points unless you put in a ballast resistor to reduce the voltage at the points. Therefore it will run poorly and require refacing the points regularly.
    I am now running a magnetron electronic ignition using the original distributor and cap. I have a blast resistor in the system too. I have done at least 30000 miles like this with no maintenance.
    Peter Hewitt
    13 September 2026 at 13:40 #83873
    Thanks both.  I’ll take your advice on parts Laurence though sadly I won’t be at AGM so will contact distributor doctor.  And James I’d be tempted by the alternator but my dynamo seems to work very well!
    I found the markings on the dizzy which indicates it’s DZ6A 40047B so Lucas.
    I have a fuel leak (again) at the filler neck which stupidly enters the tank at the middle, meaning it sits in fuel if the tank is more than half full, so I’m going to have to give that priority for now.  Had it brazed before but clearly the pinholes are going to keep returning so I’ll do a mod I think.
    Peter Hewitt
    15 September 2026 at 09:46 #83896
    Well, now I discover the distributor is from a 1940s Daimler and not original at all.  I wonder if I should try to obtain an original version – anyone know what it should be?
    Mark Norris
    19 September 2026 at 16:34 #83932
    Hi Peter, I sent my original Delco distributor to the Distributor Doctor for a rebuild. He said they were awful units and very difficult to work on due to the lack of parts. I keep a NOS Lucas DZ6 in standby for when it eventually gives up the ghost (they are a direct swop once the driven gear is attached by a roll pin). I’d change the points, rotor arm and condenser as a matter of course but also check the coil, the graphite dist. cap contact & spring as well as cleanup the HT contacts in the cap. Could also be tracking or crack within the cap. In other words all the usual suspects!
    • This reply was modified 1 month, 2 weeks ago by Mark Norris.
    Peter Hewitt
    21 September 2026 at 11:10 #83947
    Thanks Mark I think that decides it. I’ll go for all the bits for my Lucas DZ6A including the cap, which Distributor Doctor has in stock.  I have a new coil though the old one seems ok on test and it still doesn’t run properly with the new one.  I’ll replace the rotor arm first and if that doesn’t work I’ll do all the other bits in turn so I know what the problem is and have spares for the other bits.
    thanks all!
    Peter Hewitt
    27 September 2026 at 11:33 #83995
    …AND it turned out to be a combination of dodgy condenser and pitted points (latter probably caused by former I guess).  Thanks for all the help everyone
