DavidLG4520 April 2008 at 16:04 #47292
Does anyone have a horn bracket as the attached photo?
A pair would be better if in good condition as this one is a bit pitted, but usable if not. I do have a second one but several of the spring leaves are broken so not really usable.
David Eldred
Colin M3420 April 2008 at 17:51 #47293Hello David,
Good news here I think. If you comb the Beaulieu Autojumble you should find that replicas are being made out a correct modern spring steel. Fortunately, not being a safety critical item, this level of specification should suffice!
Also try the motorbike spares people because a similar bracket is used to mount a horn onto the frame on a British bike.
You may have to play with rivets and buts and bolts to get exactly the right mounting.
Good luck!
DavidLG4520 April 2008 at 18:29 #47294Thanks Colin. Not sure I can face searching Beaulieu though!
Colin M3421 April 2008 at 12:00 #47295Hi David,
Well, Google may have saved the Beaulieu trip! Try this amazing website: http://www.taffthehorns.com/ email address
lynn.isaac@tinyworld.co.uk . I’m sure readers will want to know how you get on!Colin M34
DavidLG4521 April 2008 at 17:33 #47297Thanks Colin.
No doesn’t have any. He suggests getting some new leaves laser cut (spring steel).
Sounds expensive!
Colin M3421 April 2008 at 18:55 #47298The plot thickens! Try Gregories autoparts, part number 0397, price ?8.50! Take a look at their site at http://www.gregorysautoparts.co.uk/catalogue.php
I have taken the liberty of attaching their picture to this posting
Good news I think
DavidLG4521 April 2008 at 22:21 #47299I have a pair of those in fairly good condition. The trouble is they’d need quite a lot of alteration to get one hole instead of two at the bottom. Not sure how easy it would be to cut and reshape the spring steel, plus I’d end up with the lower 2 holes cut through.
I suppose I could just make a plate to fit the two hole brackets, but didn’t want to do that really. Yes, I know I’m being fussy!
Maybe the way to go is to alter what I have if I can’t find any of the correct shaped ones.
I can revert to plan “A” if failure sets in (get another two hole bracket and make a plate)
D
