• Mike Southgate
    11 July 2022 at 05:33 #57149
    Hello,
    In the process of rebuilding the engine from an LG6 and have been asked about valve stem seals. They were never fitted originally as far as I know, and the engine currently doesn’t have any fitted.
    The question is does anyone fit them when rebuilding, and if so, what do they use? Or is this not recommended? The car only sees road use, if that might affect the answer.
    Many thanks in advance
    D R Hine
    12 July 2022 at 01:57 #57162
    Valve stem seals are not necessary however it is vital to seal the head studs with lots of PTFE tape to stop oil being sucked into the inlet manifold
    David Hine
