• Ian Harfield
    16 April 2024 at 09:19 #68254
    Hi, I need a new set of tyres for the 16/80. Age has got the better of them, planning this summer to put some proper miles on them, so time to change them. Currently they are what has been described as “budget tyres”, Excelsior 550×18.
    Having had a call around the usual suspects, the correct “look” would be the 3 stud pattern. We currently have a Alvis Special that is running Blockley 650×19, it is on the track quite a lot, as well as dirt roads and these tyres have stood up and performed well, although a bit whiny on smooths services.
    What is everyone one using or preferring / recommending?
    Len Cozzolino
    16 April 2024 at 10:16 #68255
    Hi Alan,  You should have a chat with Laurence Drake.  He fitted new Blockleys and experienced steering problems on his 16/80.   I don’t know how he  resolved it.  YOu can get his contact details from the Member’s Register.
    L C Hannam
    20 April 2024 at 10:46 #69098
    Excelsior crossply tyres seem to get poor reviews, however they also produce radial tyres for early cars, which have a very good reputation, indeed I bought a set for my Riley RMB. All the benefits of radials, but, crucially, the dimensions and appearance of period crossplies. They certainly make them in a size to suit the V12 and LG6, so quite likely for the 16/80. Only downside is … they aren’t cheap! They should however last far longer than crossplies. I think North Hants Tyres are the only UK suppliers; Longstone don’t stock as they erroneously presume Excelsior radials are as bad as their crossplies.
    27 April 2024 at 12:13 #69158
    When I bought my 16/80 it had Excelsiors which disliked and they were very old. I replaced them with Michelin DR (Double Rivet) from Vintage Tyres Beaulieu and they transformed the ride of the car. Could be because they were new but I suspect it’s because they are better quality tyres. I like the look of them too.
    27 April 2024 at 12:17 #69159
    16/80 on Michelin DRs
    2 May 2024 at 17:57 #69565
    Try again
