• Richard Branch
    23 January 2016 at 09:03 #51697
    Just a thought, how many of your cars have the thermostatically controlled radiator grill shutters operating correctly? The previous owner of my 16/80 fixed up a rather Heath Robinson manual control on my car using some Bowden cables and and what looks like motorbike hand throttle lever under the dashboard. I wonder how difficult to would be to reinstate the correct thermostatic operation? Any one got any advice?
    23 January 2016 at 09:21 #51698
    I have a similar arrangement on LG45 and also had the same on my M45. I would not dispose of your existing system without trying it fully first of all. I found that the thermostatic control was always “too late” i.e. it only opened fully a long time after you incurred problems on the road. It only seemed to open right at the top of a very long hill or when you had been waiting for some time at roadworks or congestion.
    I therefore converted my shutters so that I could operate them by hand and anticipate the problems that I could clearly see on the road.
    I know that this arrangement will not suit everyone but it works well for me !!
    23 January 2016 at 15:11 #51699
    Richard,
    I am in the process of rebuilding the thermostatically operated radiator shutters on my LG45. They worked really well until a family of pheasants hit the shutters, radiator shell and headlamp at 40+ mph…but that’s another story.
    I have had all the mechanism apart and ordered a new Calorstat that fits in the top tank on the rad (same as Bentley/Rolls Royce arrrangement so not cheap). There are several adjustment points on the shutter mechanism which should have no tighteness or resistance in its operation. Testing a new Calorstat all the action takes place at between 70 and 80C. As I never had any problems with the original system we will see what the refurbished set up performs like. Give me a call if you want to discuss in more detail
    26 January 2016 at 09:26 #51700
    I would reinforce Mark’s view. The automatic shutter arrangement on my 16/80 worked quite well.
    I was hit by a worse problem which was the radiator being blocked by limescale despite being a fairly new core. I recommend using a film core of the type fitted to LG45s or at least descaling the existing core.
    30 January 2016 at 10:29 #51701
    Hi all,
    Mark makes a very good point about making sure there is no resistance in the linkages and of course most of the linkage is inaccessible once the chrome surround is installed….
    Weber carburetor items are nice and free moving and available from ebay….
    Regarding the calorstat opening late, I guess this may have been because it had been set up for too high a temperature or leaked a bit or the linkage was stiff /not quite right and this is undoubtedly a fiddle of a job…. but they can be got to work well.
    If you want the engine to run at 70 to 80 deg C it would seem sensible to set up the calorstat to open at a lower temperature to account for the lag and I believe I agreed to just below 70 deg C when the radiator restorer did the initial set up. I quite expect the linkage will need adjusting to get this right when I get my car on the road.
    30 January 2016 at 11:18 #51702
    I have been doing some digging on the internet. Takes a look at eBay item number:151733056759 on the US site. This is for a Wahler Air Intake Box Thermostat for Volvo. I then found a YouTube video at https://www.youtube.com/watch?v=FGWXXyXD2ME . I think this is worth investigating because it seems to be precisely what we want.
    One could possibly buy one and embed it in a brass disc which slips into the housing on the 16/80 radiator. They are not that expensive so I may buy one anyway to play with. Thoughts anyone?
    30 January 2016 at 22:28 #51703
    The snag I would see there is that that operates at body temperature so 35-37 degrees. I assume the radiator grill slats start to open at around 70 degrees?
    1 February 2016 at 20:09 #51707
    Hi Richard
    That’s why I said it it might be fun to play with – perhaps in a test rig, plotting deflection against temperature. This would tell us how linear the curve is. I think the radiator slats should start to open at around at body temperature (35-37 degrees as you said) and be fully open at 70 degrees.
    The nice thing about the 16/80 (and other) radiator set-up is that everything is adjustable so you could set up the operating temperature of the engine quite precisely, according to personal preferences. I like an engine to run at about 75 degrees.
    I also enjoy repairing temperature gauges, refilling and calibrating them once all the bubbles are out. Fortunately the local pharmacist will sell me ether – usually after I explain what I am using it for. I always repair these in a well ventilated room!
    1 February 2016 at 22:39 #51710
    New Calorstats are set to open the shutters at 70c and that will give the operating temperature of 70- 75c. My LG45 sits at 70 c unless in really heavy traffic at which point it goes to 80c and never seen it higher. There is a big old fan on the LG45 !
    1 February 2016 at 23:01 #51711
    Do your slats clang open at 70 degrees or do they open gradually? Both could be achieved with a suitable linkage.
    Cheers
    1 February 2016 at 23:25 #51713
    Hi Colin,
    The shutters open gradually but as you say they can be adjusted to change the opening action. I don’t think they have ever opened fully in obtaining the normal operating temperature of 70c, they seem to open half way which is enough to get the temperature that stabilises the action in the Calorstat.
    23 February 2016 at 22:51 #51767
    In recent days have completed the fit up of the newly straightened radiator shutters and the fitment of the new Calorstat (original was called a Smithermet presumably made by Smiths Industries)
    On test the shutters do not start to open until the temperature gauge reaches close to 70 C. They open very gradually until they are at an angle of approx 45 degrees from closed, they never have opened to their full extent and would look somewhat strange if they did. Once opened the temperature gauge settles at circa 73C. This was all carried out in the workshop with doors open but I guess being outside would increase airflow and possibly reduce the temperature by a couple of degrees.
    The shutters took about 45mins to close (ambient February temperature was 5 C) and do so gradually.
    It is important that the Calorstat actuating rod is not under any resistance at either fully closed (cold) position or fully open (hot) position. On mine there is free clearance at both positions. If you have to force the position of the Calorstat actuating rod to get the old lever to fit there is a problem and it will not stand it. We altered the original lever, introducing a curve and welding and repositioning the mounting holes to avoid any stress on the Calorstat actuating rod.
    Hope this helps anyone in a similar situation. One final piece of advice….avoid pheasants when driving an LG45…it can be very expensive
