• Peter Reeves
    25 January 2008 at 14:29 #47141
    Hi Everybody
    What Oil, Plugs, filter, and points or you using on your 3 ltr. What oils are you using in gearbox, axel and other lubrication areas??
    What I would like to do is put together a service, lubrication and general servicing handout for the DB cars any help and information would be very welcome.
    Peter.
    25 January 2008 at 19:00 #47143
    Hello everybody
    I own a copy of the DB 2.6 Litre Instruction book and have scanned the lubrication chart and the list of recommended oils etc. These are attached here as JPEGs. This book is dated December 1950.
    I would expect that the 3L is similar. Obviously the recommended oils should be updated to modern versions and this would be a fruitful topic for discussion in this forum.
    I use modern oil and full-flow oil filter in my 1927 2 Litre.
    I can also scan the detailed servicing data pages.
    Colin Mallett
