• DavidLG45
    23 May 2015 at 10:40 #51274
    Does anyone know if LG45s had Wefco leaf spring gaiters originally? If they did how did they accommodate the oil pipe brackets that were mounted on the spring guide bolts on the front springs? There must be holes in the gaiters?
    23 May 2015 at 20:36 #51275
    I’ll send you pictures of mine tomorrow David.
    25 May 2015 at 18:07 #51276
    David, It’s not the easiest of things to photograph without removing wheels and having a ramp/lift but I’ve done my best.
    The gaiters are in 2 halves per spring and don’t wrap the spring bolts. I suspect our cars have a slightly different arrangement. Please call me if I can help further. Sorry if not much use.
    25 May 2015 at 18:19 #51277
    I dont know if Webco spring gaiters were used originally but I definitely dont think that they would have wrapped the ends or the spring bolts. I think it would have been impractical.
    26 May 2015 at 07:25 #51278
    Many thanks for taking the photos.Photo 3 shows it clearly. It does seem to be fixed with a plastic tie to the gaiter strap?
    On my car the pipes were attached by brackets fixed to the spring guide bolts. A couple of photos attached – one from the manual and another car being dismantled – not my car buy mine was the same. So it does seem likely this was how the pipes were attached. Perhaps the gaiter was in separate pieces and didn’t cover the guides?
    Bill, if you mean the centre U bolts then no, they don’t. The bolts I refer to are the guide clip bolts. See pix.
