• garand69
    8 October 2013 at 17:36 #50446
    Hello
    I viend to file the bolt dema Lagonda dhc de1949 the number of engine series matches well to the plate of the car.
    but when I measure the size of the cylinder that corresponds to a 2.2-liter engine
    I do not understand
    8 October 2013 at 20:11 #50450
    The diameter of a cylinder across the top from one side to the other should be approx. 78 mm. This is for the 2.6 litre engine.
    if you post a picture with the cylinder head off, I can confirm if this is the correct engine.
    You probably know already if you have removed the cylinder head, that the head gasket is copper, and a replacement will be needed and they are reasonably expensive.
    ray sherratt
    8 October 2013 at 21:34 #50451
    I don`t under stand the need to leave carbon in the liner,
    any carbon deposit leaves a risk for pre-ignition. So-long
    as liners and pistons arn`t disturbed, there shouldn`t be
    a problem. The gasket is a costley item but at nearly ?400
    with the dreaded vat and p@p I wouldn`t call it reasonable.
    Ray Sherratt.
    garand69
    9 October 2013 at 03:26 #50452
    Hello
    I will send you pictures of the engine but I can not seem to post on the site
    the engine will be rebuilt ( indiquermoi your email address to send photos)
    my problem is the size of the stroke are 72 minutes instead of 90 minutes
    the diameter of the piston is 78 minutes as expected
    this is a de2.2 liter engine instead of 2.6 which has answers to this ?
    9 October 2013 at 07:12 #50453
    Send the pictures to my email address, and then I will post on here for you.
    garand69
    12 November 2013 at 05:12 #50529
    HELLO
    MY ENGINE IS 2.6 LITERS NOT 2.2 THAT GOOD
    CYRIL
