    4 April 2021 at 07:21 #53270
    Hi David, I have experimented with batteries for my LG45 and found that the quality ?out there? seems to be variable. However, in 2015 I fitted a pair of 404/19 102Ah Classic 6V Best batteries and they have been excellent. Still providing plenty of cold cranking amps although this winter I needed an extra battery pack to start it when the temperature was just above freezing and it had been sitting for 2 months. That was probably asking a bit much though as I still had thick summer oil in the sump.
    Batteries available here https://www.batterycharged.co.uk/shield-404-6v-classic-car-ba-1050033.html
    Not cheap so check the dimensions fit your setup.
    I hope that helps.
    4 April 2021 at 08:10 #53271
    That’s the battery I have been looking at and thinking of getting.
    Good to have you confirm that it would be a good choice.
    4 April 2021 at 10:49 #53272
    Hmm, the battery I used in my LG6 was actually the one fitted to my Riley RMB in 2015, a Shield 291 (thus a single 12 volt battery), and that had been replaced under guarantee due to a faulty cell even before I collected the car from the body restorer. I last drove my Riley in 1975, and the car rewarded me by running 2400 miles in 7 weeks before running a big end. The battery then saw temporary service on my John Deere mower (which may not have been too kind to it, to be fair, no smooth lawns gere!), before being used in my LG6. The LG6 broke down in 2019, and I’ve regularly charged the battery since, hoping to use it for the V12, initially. Not to be. A cell has failed. Not too impressed, just 6 years service from a rather expensive battery, I’m used to seeing 10 years plus. So I’m not too sure I’ll go the Shield route again, but to be fair, it had a lot of jolting and vibration on the John Deere, and lack of use is not good news for batteries. Mind you, my restorer averred when I originally suggested Lincon for the battery, that Shield make the batteries for Lincon. I’m not sure that is correct, Shield state that they are the only manufacturers of such batteries in the UK, whilst Lincon state they have been batterymen since 1908 and specifically state that their batteries are manufactured on-site. Someone is telling porkies! The classic battery list for both appears remarkably similar …
    So the reality is perhaps that, whatever is said, there is in reality only one classic battery manufacturer, in the UK anyway. Holthausen’s book demonstrates that Bosch supply classic batteries, so that is an option, perhaps!
    12 April 2021 at 11:46 #53277
    I haven’t forgotten, still getting round to taking photos.
    Meanwhile, a little more research. Firstly, your Z4166 number will almost certainly be the Lagonda factory part number. Most of their part numbers for my V12 are Pxxxx, but a smattering are Zxxx, eg the wheels are Z4101/2.
    Have at last come across a 1939 Lucas catalogue online. This frustratingly details many cars, but not Lagonda, for most items. Perhaps there’s a separate section at the end I haven’t got to yet! Nevertheless, struck gold with “Batteries”. This states that 1935 (and on, going by their style) 4 1/2 litre : 2-6TXR13. For 1938 LG6 and V12, 2-SLTR15E … thus it differs slightly from the 2 units SLTSR15E detailed in the handbook. Needless to say, it can’t even be that “simple”. My works record states (Lagonda part number P8017) 6LTSR15!
    The 6TXR13 is also noted as fitted to 1931: all models, 1932: Supercharged, 1933: 2 and 3-Litre. The only other vehicle using a 6TXR13 is the Hispano Suiza 30hp; interestingly, the 37.2hp has a 12TXR13. Raises an interesting point as to the meaning of these references. 6 and 12 are obvious, but some, like those for my V12 have neither stated. I’d take a guess that the other number featured is the number of plates. The letters? Conjecture S = Short, L = Long, T = Tall, X = Extra, R = Regular, W = Wide. But then there are Ys and Ds.
    I think I’ve found an answer re the voltage absence for the V12 & LG6 reference. They are Lucas Lucas batteries; the 6TXR13 is a Lucas CAV battery! This also disproves my theory (already!). Two grades of battery are tabled; the basic version of the 6TXR13 is 6TXW13. The listings are headed (basic) “WOOD SEPARATORS”, whilst the 6TXR13 is under “DELUXE MODELS WITH THREADED RUBBER INSULATION”. Thus, W = Wood, and R = Rubber. Cor, this reminds me of algebra!
    The 6TXR13 specifcation is: Actual capacity in amp hours when discharged in 10 hours; 75amps, and in 20 hours, 85 amps. Length 8 1/2″, Length over lugs 9 3/8″ (in other words, that will presumably be the original spacing for your mounting studs), Width 6 7/8″, and Height over terminals 9 1/2″. Regarding that latter, note that the height with cover isn’t stated, probably because the cover was an extra, 5/6d!
    Unfortunately for me, not so easy for my V12 batteries, there is no reference close enough, but perhaps I can figure something out. I can see that the only other cars fitted with 2-SLTR15E were Alvis SP25s and 4.3s.
    14 April 2021 at 10:58 #53278
    Hi Laurence,
    I think you’re right about the Lagonda factory numbers – my wheels are the same number as yours, Z4101/2.
Viewing 5 posts - 16 through 20 (of 20 total)
