Alec Rivers-Bowerman18 June 2014 at 05:22 #50903
Dug out my old heat transfer book from school and ran some numbers with water and with ethylene glycol. For the situation I chose (steel 25mm pipe, 3 m long, flow 20mm/s, pipe at 80 degrees, inlet water at 60 degrees), the ethylene glycol only picked up 60% of the heat that the water did. The output temperature was lower too. Since our prewar engines were designed for water only (going by my 1933 manual), cooling with even standard antifreeze mix might start to be marginal in extreme conditions.
AlecJulian Messent18 June 2014 at 07:06 #50904Hi all,
sorry I missed this post, been extremely busy and feel terrible about saying “I forgot to clock in for a chat”
I just had a good chat with David on the phone last night and seem to be on track now thanks to all the good info here, of which I agree very much with.Generally the Meadows 4.5 is a very good reliable and strong engine, however calcium, old designs, uprated engines, blocked rads and socks, corrosion in the head and block etc all reduce the capacity of the basic system to control things.
With a new block and head, engine fully rebuilt with all the right stuff and the later LG water passage addition in the back of the block/head, all fitted with a new water pump. A standard but fully re-cored and perfect M45/LG45 radiator can cope with a 200+bhp reliably and efficiently with no overheating, even in a hot climate. (obviously the full power is not used all of the time, or even part time on the road)
This does show us that we do need to keep the whole package in tip top condition, and if we do, it will look after us. We always use water with a little glycol to limit corrosion and/or freezing, depending on the month.Blocks and pistons are and always will be a talking point and the use of liners especially.
I don’t want to preach here but we have the following rule and we stick to it extremely rigorously.
If the block needs more than one liner in any pair. ie. 1 and 2 3 and 4 5 and 6 then the block is scrapped. We will not build around it even if the customer insists. We know it will come back, usually within one year and we will have a warrantee case on our hands. (we don’t like that ;o)
The reason is two fold. a. heat dissipation is limited, even if fitted very well. b. there is not enough material left between the bores and this thin area cracks extremely quickly, especially if the liner has a good “fit” the liner then loosens, and even if it has a “top hat” section at the top to stop it from slipping down, it can still spin and then the rod hits the cut-out and Bang!! we have lots of these to rebuild so like other people who do it :o) Not really, but we do see a lot of them. My only advice if you are forced to use a fully linered block is to pin the liner in place as well as press. and use a good modern piston with a good clearance. We use 0.005″ for road and up to 0.010″ for racing. but the clearance depends on the manufacturer also. Volvo pistons need 0.008″ in my opinion and experience but we don’t use these as they tend to be noisy at this setting and tight if set smaller.Very interesting thread this though so thanks for posting David but sorry for the reasons behind it.
JulianMaybe we should start a page especially formulated to be a problem reference page with a quick search function etc?
Very best regards to all.
JulianPS.
Interesting maths Alec, I like it!David Bracey23 June 2014 at 06:18 #50909Thanks everyone,
Julian, It is very useful to get your thoughts and suggestions. It is also quite reassuring to those of us with these problems to hear that you are so confident about the solutions. You have probably seen more of these cars frailties than the rest of us put together.
With my new block, conrods, pistons and oil pump and a proven working water pump it sounds like I have everything covered so fingers crossed. I will report back once all the new parts have been fitted and tested.
I will not be putting Evans waterless back in however.
David
Giralda fan8 July 2014 at 11:57 #50928Very sorry to hear of your woes but very grateful to you for sharing them and I congratulate you for keeping your car as a saloon.
About 15/20 years ago we did have problems with that bottom hose, I discovered (eventually) that it would collapse when revs were up. The collapse was not obvious at first as the hose went back to its usual shape when the revs dropped and it wasn’t easy to see through the blur of the fan ? but sudden temp changes and boiling were the result. It is just starting to show signs of collapse again above 1500rpm but not so badly as to cause any noticeable cooling problems. On our car the exit from the rad and the entry to the pump are slightly misaligned which puts an extra stress on the hose distorting it very slightly and making this problem more likely to occur. The rad was re-cored before the problem first occurred and had been run with either a sock or stocking for most of the time since so I do not think rad blockage was an issue, its just that that section of connector/hose/connector presents one of the greater restrictions in the system I suspect, and in our particular case one which can easily accommodate the pressures on it by collapsing.
Thank you both David and Alec for the links about Evans which are very helpful. In light of the above I think pressurisation is essential and consequently I would not choose to use Evans. However, I also have great doubts about replacing water with a coolant with lower specific heat capacity in a cooling system which is already compromised by a wide variation in coolant flow rates through the engine (or so it appears to me!), and crucially which lacks the ability to be as self circulating as water is when heat is applied to a motionless or very slow moving volume.
A cooling system oddity came to light in the late 80s when my father replaced the coolant manifold and discovered that the tank engine manifold was substantially obstructed between the two block connections by an irregularity in the internal diameter of the manifold. The result of this was that 4,5,6 would probably have been getting a lot less coolant than 1,2,3. The spares scheme replacement did not have any such obstruction/constriction, nor did the manifold that my father had removed from the car’s original (blown up!) engine. We dismissed it at the time as a casting failure that we had been lucky not to be affected by. More recently I have begun to wonder if it might just have been intentional – your own case adds to my suspicions. However, it is also odd that historically 5 and 6 seem to be the problem bores (my father had no5 rod through the side of the original engine when the piston seized/broke up) but our tank engine had survived this manifold obstruction for 35 years before it was removed. This could be partly due to the fact that it is (now) a well worn engine and uses a lot of oil ? so rings and pistons are kept cool by this as much as by anything else.
On the subject of a bigger waterpump: has anyone else ever had the experience of finding a central heating radiator very hot at the bottom and barely warm at the top, and not having any air to be bled? I found that normal flow through the radiator could be restored by further closing the return/exit valve (and not the flow/entry valve) until normality was restored. This happened after I turned up the pump speed during cold weather to improve flow to rads at the very end of the system. Too strong a pump and thermo circulation/turbulence in the extremities could be reduced perhaps? Its just a thought, I have no direct experience of this in a car engine!
The only time I have ever seen melted HT leads was on a modern with a head gasket leak that had been driven flat out on the motorway until all the coolant had gone and eventually it melted a hole in a piston. On our M45 the distributor side HT leads are perilously close to the exhaust downpipe but still they haven’t melted.
It would be interesting to know what clearance Adam Pointer went for on the new rings, I will need to consider new rings very soon as oil consumption is not good, that is unless a more profound and expensive remedy is required.
Apologies for being late to the party on this topic – my first post too!
James
Peter S3014 July 2014 at 11:58 #50938I am not a very experienced long time Lagonda man (only ten years now) but engineer and I think much of these overheating problem (see also the M45 stuck in London traffic on the way to “the one show”, equipped with electric fan) is due to restrictions in water circulation. I think this goes in line with most of the previous posts on this topic.
I had this on my V12. The car would boil at low revs e.g. driving on the highway and then get into stop and go in a traffic jamm or at the end of a mountain climb. The water temperature at this point still beeing acceptable. Electric fan or new radiator does not help much in this case because the water is still cooled well but does not reach the hot areas at sufficient rate. The reasons are:
1. Problems in the design at first (was still ok when the car was new)
2. Water pump with less performance due to corroded rotor
3. Corroded water passages plus lime depositThe cure is: solve the above 3 problems, at least the last 2, especially if you do a complete engine overhaul. Or put an electric water pump as temporary cure for the problem. I did the last (in series to the existing water pump), I switch it on when I anticipate it will be needed (slowing down after strong going, traffic jams) and it works. And if I forget to switch it on then I have the boiling, quite reproducably.
Things would be different if the true water temperature (measured with a correctly reading device) goes to high, then I would go for radiator clean, electric fan, new readiator.
I prefer water as coolant, when it boils=evaporates it cools extremely well and this boiling indicates the problem early. I will not try waterless coolants.
David Bracey21 August 2014 at 11:55 #50966Time to provide and update on progress with my LG45 engine rebuild.
The new block has been machined to suit the new pistons. Unfortunately the conrods supplied are the wrong size so have been returned to LMB for them to investigate how that problem has arisen and so things have stalled somewhat.
Unfortunately this now means that the car will not be ready for the Lagonda Club AGM so I will have to come along in a modern car.
Anyone else doing better than me?
bill15 November 2014 at 09:48 #51068Just as a follow-up on the controversy about waterless coolants. I stand to be corrected perhaps but I have been informed on apparently very good authority (by someone who designs cooling systems on modern vehicles for a living) that “waterless coolants” are nothing more than neat antifreeze. I understand that nothing is better than water at dispersing heat and antifreeze does not do this anything like as well as water – therefore it is possible that there can be localised overheating in an engine with “waterless coolants”. This overheating is not manifested as boiling or rising temperature as with water.
Maybe this is the reason why “waterless coolants” are not recommended for thermo-syphon systems ?
Take great care !!bill17 November 2014 at 18:40 #51070Just in case you missed it on the VSCC Forum there was an answer about my thermo syphon system point above posted (by someone who seemed to know) as follows : –
“I suggest that the reason is because Glycol does not expand as much as water, does not absorb as much heat per pint, and is thicker (more viscous). All these factors make it less successful in a system which relies on expansion, etc to work, with no pump.”
Of course if the coolant does not absorb as much heat (as water) then maybe this is the reason why you can get localised overheating in a system which is very inefficient in design (as I think we all know).
Anyone with more technical knowledge out there care to comment please ?
Bill LG4520 February 2015 at 22:53 #51166Ethylene Glycol plus inhibitors is the commonly used car antifreeze in older vehicles (usually blue or green) and the thermal conductivity is approx half or less than that of water.
In high concentration levels, as needed for winter protection, it will mean that the engine is more likely to boil as is not able to carry the heat away as well as fresh water.
Personally I run my old cars on a relatively high ethylene glycol concentration (30 to 50% in winter and dump the antifreeze in the Spring, retaining only about 5% to keep some corrosion protection. Dumping this ethylene glycol antifreeze annually also makes sense because it only has approx. 2 year life before the inhibitors are “used up”.
When they are “used up” these silicate inhibitors tend to come out of solution and cause wear to water pump seals / bearings.
Nasty gels also form which bung up the system aside from the corrosive nature of gylcol when the corrosion inhibitor is used up.From Google:
Fluid Thermal Conductivity at 300 K ( + 27 degrees C)
(W/m K)Ethylene Glycol = 0.258 versus Water, Fresh = 0.609
I am not sure what chemical is actually in the “waterless” antifreeze either.
I tried a particular waterless type in a Mk VI Bentley we had which had been prone to overheating as they claimed that the thermal capacity was better than water but I found that it did two things:
1. It acted as a very good flushing agent and cleaned all the dirt out of the engine, depositing it in the radiator so it was just as well we needed to re-core the radiator anyway!
2. It was far more “searching” than ethylene glycol and found every possible place to leak out of!
so it might work well with systems that are totally clean and leak free but I would not introduce it to an older engine that had previously been used on water unless it had been meticulously cleaned inside …..
So, having cleaned the engine out I re-cored the rad, reverted to ethylene glycol and fitted a new water pump which solved the problem and was what we should have done in the first place!
Hope this helps
Billbill21 February 2015 at 09:13 #51167Thanks for all that information Bill as it rather confirms everything that I had come to believe about waterless coolants. I do however find it rather worrying that these expensive “waterless coolants” appear to being “pushed” quite strenuously at vintage and classic car owners – as if these products are the answer to all our problems !
David Bracey21 February 2015 at 12:37 #51168Dear BillLG45
I think you’ve just about summed it up perfectly. Waterless it may be but better that water it isn’t.
David
Colin M3422 February 2015 at 22:47 #51169Hi Chaps
I have been following this discussion with interest and have two points to make.
Firstly, I am a great fan of cutting oil (suds) which I use on my lathe and milling machine. It has interesting properties. Not only does the metal cut nicely with a great finish, but when you spill some on the floor the detergent properties show up as well.
In fact the only problem with using cutting oil is that it stinks and my wife complains that I “smell of garage” which I remedy with a few drops of Jasmine aroma therapy oil which makes the workshop smell lovely….
With cars, I am also an old fan of a product called ” Bar?s Leaks Radiator Stop Leak”. When you add it to the cooling system the brown liquid goes white just like cutting oil. Has anybody any experience of using cutting oil in a car cooling system? I think it might work rather well.
Secondly, I have also been servicing my central heating system and used Fernox DS3 to de-scale the domestic hot water heat exchanger on my combi boiler. I now have lovely hot baths again. As many of you know, DS3 is our old friend for de-scaling car radiators as well. I then started thinking about central heating treatments such as Fernox DS40 system cleaner, as well as MB-1 which is an all-round protector. DS40 is very good at flushing lime-scale and black sludge etc from a heating system. Surely, isn’t this what we need for our cars? Opinions please?
If anyone thinks that I am barking up the wrong tree, please tell me.
If I meet any fellow readers in a pub and I smell of Jasmine, you will know what I have been doing…
David Bracey14 March 2015 at 09:51 #51193Ok, an update.
My engine is now back together and running very well (not that I’ve been out on the road yet.) But the ignition and valve timing has been set with both magnetos seemingly synchronised.
Before refitting the radiator we wanted to flush out the waterways and prove that we had good water pump flow throughout the rpm range so we connected up a water container and hoses so that we could see what was going on. The flow rate looked pretty good to me but I’m not sure what I was expecting. Personally, I was happy with the results.
I’ve posted a short video clip on youtube here: –
https://www.youtube.com/watch?v=erP9cdaj9bo&feature=youtu.be
The video is brief because I needed to keep the file size down but you can see the flow we are getting at about 1,300rpm
Once initial road testing has been carried out I will post a fuller description of what was done, problems encountered, and lessons learnt but if anyone has anything else to throw into the mix I would appreciate it.
David Bracey3 April 2015 at 20:12 #51200Thank you for all the advice, suggestions and wishes of good luck that I received following the engine problems I encountered with my LG45. It really was a great help. Without wishing to tempt fate I believe I have now sorted those problems and have a car that will be reliable and which can be driven extensively as I had always hoped.
So, what have I learnt and what conclusions have I reached?
Following Julian?s advice, the new was machined with 0.006? clearances for the pistons. Unfortunately, fitting the new block, conrods and pistons was a much more involved process than it should have been. All were bought from the same source but there were problems fitting them. For instance, the block was not supplied fully machined and the conrods did not have the correct offset to suit the old crankshaft and neither did the big end fit the crank. It was necessary to machine the inside of the pistons to provide the offset necessary so that the conrods could be used. It was also necessary to machine clearance slots in the block so that the conrods didn?t foul. All this created unnecessary frustration, delay and expense and was very disappointing.
A new oil pump was also fitted.
Once assembled the engine was set up carefully and it fired into life without any difficulties at all. As reported previously I took Julian?s advice and ran the engine from a water tank so that we could flush out any crud before connecting it to the radiator. I used demineralised water and NOT Evans. Using the water tank also gave an excellent opportunity to check the flow rate being achieved across the whole rpm range. This confirmed that everything was performing properly and so the car was completely reassembled.
Before road testing we attached adhesive temp sensors to the block, head, water transfer plates and radiator hoses so that I could see the maximum temperatures reached. Last week I did a 200 mile test over 4.5hrs and it performed perfectly. Good oil pressure throughout and a steady water temperature of about 65 degrees. The maximum temp recorded with the engine bay sensors was 73 degrees. I did another 50 miles and then the head was pulled down and oil changed. I?ve since covered another 250 miles and the car is running and sounding great.
Looking at the original block, conrods and pistons I think I could have probably re-used the block and conrods if it had been rebored to 0.006? clearance, fitted with new pistons and if I had used water instead of Evans. No1 piston had seized to the gudgeon pin which clearly implies excessive heat and possibly insufficient oil circulation.
Anyway, despite the obvious costs involved, and unnecessary problems with the new parts, I don?t regret using new components. Having spent so much time and money already I really needed to take every option available to give me a truly sorted car and that is what I now have. Hindsight is wonderful but I needed as close to certainty as I could get.
I hope that this will all be useful to others and hope that the lessons learned will prevent anyone else having similar problems. If I can be of any help to anyone else please get in touch. Likewise I would be grateful to hear any comments or observations that may arise.
I hope to see you at the Lagonda Club AGM in October ? I?ll definitely be there!
bill4 April 2015 at 08:25 #51202Well done David. It looks as if your extreme persistence has been rewarded. Many others would probably have given up ! I hope you now have many happy trouble free miles.
Thanks very much for the conclusions which I am sure will be very useful to others.
As a matter of interest what oil are you using ? -
