    6 February 2013 at 09:14 #49993
    The battery compartment appears to measure L375 x W190 x H150mm, most car batteries are a minimum of 175mm high – am I mis-measuring the available space (taking into account the fibreglass lid) or do you have to get a very low battery?
    6 February 2013 at 13:13 #49996
    The battery may well sit proud of the compartment, hence the raised lid, about another 25 mm. Fit the biggest Ampere-Hour you can find with the terminals in the right place for the leads (positive on forward outboard side if I recall)
    6 February 2013 at 13:56 #49997
    The metal section is about 4″ (100mm) deep excluding the base board and the fibreglass section is about 2″ (50mm) – so obviously together that’s 150mm. Lucas do a simular battery which is L350 x H175 x W175mm – 95Ah – the hight appears to be the problem. The position of the terminals won’t matter as I’m reversing the polarity and fitting a new earth via the isolation switch.
    6 February 2013 at 16:14 #49998
    Sounds as if your battery compartment is shallower than on my car, where the metal section looks (from memory) 6-7 inches deep above the base board
    6 February 2013 at 21:18 #49999
    Just re-measured from under and I think 175mm will just fit…
