• Barry Brown
    9 May 2011 at 10:01 #48206
    A threaded stud emanating from the centre cross member. What is it’s purpose?
    Alistair Crawford
    15 May 2011 at 16:38 #48228
    Barry,
    I use it for hanging an air freshener, or some of those lucky furry dice.
    Will have a look under my M45 and see if I have a similar thingy with anything attached
    Alistair Crawford
    15 May 2011 at 16:49 #48229
    Barry
    I have just looked at my M45 and it just has a small filled hole there, presumably where the threaded stud has been removed from
    15 May 2011 at 17:03 #48230
    At the pace my recommissioning/restoration is going lucky dice may be a good idea! The mystery deepens. Thanks for checking. Could you also check the location of engine numbers? The only number I can find is M45/17 near the oil filler which I have been told is the Meadows number. I can’t find the Lagonda number.
    15 May 2011 at 19:59 #48231
    Hi Folks, here is my explanation.
    The M45 is based on the ‘ZM’ chassis which was developed for the 3 Litre “Selector Special”. This was fitted with the Maybach gearbox. This gearbox had a three point mounting consisting of two forks at the front and the stud in question at the rear. The “Selector Special” was a commercial failure and most 3 Litres have the ‘Z’ gearbox instead. This required a new subframe which uses this stud as the rear fixing.
    For the M45 the Z gearbox was replaced by the Meadows ‘T8’ unit which has different rear support arrangements which render the stud redundant.
    If anyone has any more to add or disagrees with this explanation, feel free to add something to this debate.
    Cheers
    16 May 2011 at 07:43 #48232
    Folks,
    Looking further into Arnold Davey’s excellent Lagonda Book, I read that the first few M45s actually came out of the factory with the ‘silent third’ version of the Z gearbox. These were later recalled to have the T8 box fitted, so the Z gearbox subframe connected to the mystery stud would have been unbolted and no doubt recycled on a Three Litre of the same period.
    Cheers Colin
    10 November 2017 at 03:07 #52543
    Colin! Thanks for the explanation! I appreciate it, Sorry I took 6.5 years to thank you! Anyway, I am back at the project having fun. Frame has been dismantalled and blasted and epoxy primed. Now the real challenge begins! Cheers, Barry
