• 19 December 2016 at 17:35 #52214
    I am desperately seeking a serviceable 2 Litre Low Chassis light(OH) axle differential with a 4.2 crown wheel and pinion.
    Mine has suffered terminal damage.
    A differential unit needing just a new crown wheel and pinion would be an option.
    Any help or advice pointing me in the right direction gratefully received
    Mark (Register no. Y2)
    Tim Parker
    20 December 2016 at 14:16 #52217
    Hi Mark
    Bad luck. I was in the same boat in the summer and managed to find a diff thanks to the Suffolk mafia, but before that I found an early light axle diff cage casting at David Ayre’s store. The club will sell you a new cwp. So you might be able to fit your diff internals with a new cwp to the cage. I didn’t buy it so he might still have it.
    The other option wd be to fit a heavy axle – 3L axle was for sale in club newsletter last month, but that is more of an operation I appreciate.
    I have some spare planet gears etc leftover from my summer diff job if that wd help.
    Kind regards
    Tim
    23 December 2016 at 10:24 #52222
    Thanks Tim,
    I believe the recently offered heavy axle has now sold, but as you say, remaking all the rear wing brackets to take account of the additional width would be a pain.
    The whole axle has turned out to be a bit of a mess. There is evidence of some home made repairs in the half shaft department! ….so have to replace those as well.
    As for the differential it is extensive gear wear/damage and bearing wear ..so the casing/cage is hopefully ok. I will try to send you a PM regarding the planet gears, so we can make contacts, they may get me out of trouble
