• TVJL
    14 October 2010 at 14:46 #47910
    Can some kind person list the individual tools that were usually supplied in the tool kit of an M45 and/or LG45, please. Photographs of the tools and their location in cars would be wonderful too, if possible. Thank you very much in anticipation.
    Tim
    30 October 2010 at 21:22 #47925
    Hi Tim,
    The factory handbook for my V.12 lists the tools supplied, so it might be worth finding/borrowing the appropriate handbooks. Tools for the LG45 would have been stored in the n/s “wheelcase”; jack handle, starting handle & inspection light in clips, smaller tools in a selection of pockets affixed to the inside of the opening section of the wheelcase. Not sure where they’d go in an M45, or indeed an LG45R. Larger tools I imagine would have been supplied in a tool roll….I have one for the V.12 which I assume is original.
    31 December 2012 at 10:16 #49951
    Hi Tim,
    I’ve got the same question so wondered how you got on accumulating the correct period tools.
    The handbook lists an extensive Tool Kit as Follows: –
    Spare Tecalemit filter element
    Adjustable Spanner (large)
    Adjustable Spanner (small)
    11″ Screwdriver
    7″ Screwdriver
    8″ Half Round File C/W Handle
    1/2″ x 7/16″ Double Ended Set Spanner
    3/8″ x 5/16″ Double Ended Set Spanner
    1/4″ x 3/16″ Double Ended Set Spanner
    3/16″ x 1/8″ Double Ended Set Spanner
    1″ x 11/16″ BSF Double Ended Box Spanner
    1/2″ x 7/16 BSF Double Ended Box Spanner
    5/8″ x 5/16″ BSF Double Ended Box Spanner
    5/16″ x 1/4″ BSF Double Ended Box Spanner
    3/16″ Whitworth Single Ended Box Spanner
    7/16″ dia. Tommy Bar
    5/16″ dia. Tommy Bar
    1/4″ dia. Tommy Bar
    6″ Centre Punch
    Pliers
    3/4 lb. Hammer (Ball Ended)
    Single Ended Spanner, 3/16″ Whit.
    Copper Hammer
    Tyre Gauge
    Tyre Valve Key
    Tappet Gauge
    Mag. Spanner
    Box Spanner – Cylinder Head Studs
    Sparking Plug Spanner
    Oil Gun
    Saddle Piece for Valve Removal
    valve Spring Compression Kit Beam Tool
    Valve Holding Tool
    Foot Pump
    I have a small selection of these with my car but would like to build it up eventually. If anyone has any tools that they think are original from this list I would love to see photo’s or get a detailed description of makes, lengths, markings, etc.
    Best regards,
    31 December 2012 at 11:13 #49952
    The tools in my V12 tool kit are all made by Shelley, but of course it’s possible Lagonda used a different supplier previously. I can only be certain that the inspection lamp was the same (although if you want to be pedantic, it’s possible the finish on that was different), that of course is a Joseph Lucas product.
    31 December 2012 at 11:31 #49953
    Hi Laurence,
    That was quick! Did the V12 have a similarly extensive list?
    31 December 2012 at 13:36 #49954
    Holy mackeral! No boring bar? That list is either very thoughtful or ominous. I too would like to gather what’s available. I have a few Shelley spanners. I hope Lagonda did not use Jenbro as these have been bid up to ridiculous sums by Vincent motorbike enthusiasts.
    31 December 2012 at 15:17 #49955
    Ha! I agree Barry. It’s impressive isn’t it. That is the list in the LG45 handbook although I imagine it slowed the car down! I think I will stick to Shelley spanners rather than Jenbro.
    3 January 2013 at 14:22 #49962
    Just checked the V12 handbook, and the list although largely identical is even longer…but does include “Licence holder” (a tool?!), Leather bag for large tools, spare spark plugs, various special items for the hydraulic brakes, & a special spanner for the (Hypoid) rear axle.
    Perhaps the perception was that owners expected a formidable & comprehensive array of tools when purchasing such an expensive car, but I wonder how many original owners thought of actually using the tools, as opposed to having the car worked on…especially given the effectively lifetime guarantee depending on regular works overhauls and carte blanche approach to replacing anything they saw fit?
    3 January 2013 at 14:54 #49963
    Thanks Laurence,
    What remains of the original tool roll doesn’t look like it would hold half of the tools the handbook lists.
    I have the valve spring compression tool which I guess would have been the hardest item to replace so that is something.
    I wonder what Lagonda thought you might need the 8″ half round file for?
    If you were able to send me a photo of the V12 tools at some point it would be really appreciated.
    Thanks again.
    3 January 2013 at 17:23 #49964
    What worries me is the 6″ centre punch, inviting owners to commit butchery!
    If your car is similar in that respect to the V12, the N/S (dummy) wheelcase should have a panel held on by the hinge plates that is leatherette covered and stitched to accept presumably all the smaller tools….can send a picture if yours is missing.
    My tools (mainly) didn’t come with my car but were purchased from the late John Finch…I was really pleased to find that many were stamped “WAR FINISH”…ideal for my car, registered December 1940! I can’t recall now if they also came from John, but I’ve also got some Lagonda factory tools, stamped with an engineer’s name.
    Yes, happy to send pictures, please pm email address to me. I can’t promise to get the pictures done soon, but as soon as I’ve got some spare time I’ll find them & take them. Intrigued also to see what the valve spring compressor looks like…is this the special toolkit one that retains the valve via the spark plug orifice, thus enabling spring changes without removing the cylinder head?
    3 January 2013 at 17:59 #49965
    Please post pictures here if not too much bother as I am sure there are others including me who are interested in this subject.
    3 January 2013 at 18:22 #49968
    Will do if I can but my last attempt didn’t work!
    3 January 2013 at 18:36 #49969
    PROBABLY TOO LARGE A FILE. IF USING A MAC just export the picture to documents and make sure you change it to jpg format when given the choice , then choose smallest quality and large size, this generally gives a good picture under 150 kb. I am still learning as well
    4 August 2013 at 13:01 #50281
    I just “discovered” this unfortunately empty tool roll that was amongst my M45 project. I initially thought it would be stashed under the rear floor boards but on second thought that would be a lot of weight hanging down so maybe behind the rear seat? Any ideas?
    Alistair Crawford
    4 August 2013 at 18:50 #50282
    Barry
    on my M45 (which I have now sold so no pictures) this carpeted panel with the handle and small bolt was upright on the left hand side of the passenger footwell. So you could keep tools or mapbooks in a vertical compartment between this carpeted panel and the bodywork, to the depth of the wood frame of the car. hope that makes sense!
Viewing 15 posts - 1 through 15 (of 17 total)
