Norman Smit2 February 2022 at 18:49 #53837
Who can help me.
I’am the proud owner of a nice LG45. Now I found a new number on the chassis, but not the chassis number. I’ve found the chassis number on the top of the chassis beam near the steeringhouse. But on the vertical side on the same beam a found a number: 69.35/6. i’ve some doubt of the / it’s a little bit curved and not simular deep).
Who can tell me more?
Len Cozzolino2 February 2022 at 19:57 #53839Hi Norman,
The number stamped in the chassis frame should be the same number as the “Car Number” on the ID plate on the bukhead. All LG45 had a car number (which is the chassis number) starting with 12xxx. The engine number has the same format. The 69.35/6 means nothing to me and I doubt it is a factory number but I will check for you. What is the Car number on the iD plate and I’ll check in our records to see if this number has any relevance. (I am the Assistant Registrara of the Lagonda Club) If you prefer you can email me direct on len.cozzolino@lagondaclub.com
I look forward to hearing from you
Len
