• h14
    22 August 2019 at 15:13 #53049
    I’ve driven some 15,500 miles in my LG6 since purchase in 1997, and shortly after buying it, corrected the camshaft timing and adjusted both camshaft and magneto drive chains. Perhaps I wrongly assumed such substantial, and relatively lightly loaded, chains would not need revisiting for at least 30,000 miles. BUT … throttle pedal stuck open last week, engine raced, then popped and banged, and wouldn’t restart.
    On stripping down, I find both chains have too much flop, and have obliterated the outer pipe and almost cut through the inner one. It, or at least mine, has “4110” stamped on the brass, probably a Meadows part number.
    Anyone got one of these going spare, or that I could borrow until I get the engine rebuilt next year? Needed urgently as I hope to leave here, en route for this year’s Annual Gathering, in the LG6 4th September. I suspect this part remained unaltered from early days, so one from an M45 or LG45 would suit.
    30 August 2019 at 07:35 #53050
    Morning,
    Easy answer.
    Cut off pipes, block ends with solder and drill a 1.5mm hole in each.
    That gives more than enough oil for the chains and stops any chance of this happening again.
    We do this on all our race engines and never ever have problems again.
    Best regards,
    Jules
    3 September 2019 at 09:16 #53052
    Hi Julian,
    Many thanks, useful tip!
