• mehere
    18 July 2018 at 18:39 #52843
    I promised I would put this “for sale” here for a good friend [non Lagonda owner] ….. -he is looking for “around” 12k
    Meadows 4.5
    Meadows number 8048
    Lagonda number MG45 111
    Crankcase, Sump and all alloy parts in excellent condition, will require re-bore and new pistons.
    Block away to have new liner fitted to replace damaged lower spigot.
    Head, all seats re-cut and face checked along with block top face.
    All parts to include valves ,springs, cups and cotters, timing chains, sprockets, camshaft, followers oil relief valve, Lagonda rocker cover ,magneto mounting,
    Crankshaft and 6 con- rods, oil-pump, front spring damper ( dismantled) , C/S keys, thrust washers and starter dog. Clutch centre plate. Will req full re–metal
    I starter motor condition un-known
    Missing parts
    All rocker gear, push rods, one push rod cup, fly-wheel and clutch cover. Distributer
    To the best of my knowledge all the parts are present with the engine even if not listed here, entire thing is fully stripped and inspection is welcomed.
    One 6 cylinder Scintilla mag (condition unknown) can be available as a separate item.
