• jay
    3 May 2013 at 21:43 #50148
    hi im looking to replace the boot carpet as its well worn now,just the floor section.
    can anyone tell me if the same carpet is still available or where to get one made
    thanks
    4 May 2013 at 15:52 #50152
    Jay, try a call to Lincoln Scott car trimmers etc in Lewes
    4 May 2013 at 19:43 #50154
    It’s unlikly that the original loop pile carpet is available – I’ve looked long and hard. Over the next few months I’m going to try and find something similar and will let you know what I find…
    4 May 2013 at 21:34 #50155
    Jay hi
    I would suggest following David’s advice, these people have an excellent reputation in the AML world
    The phone number is 01273 891989
    Nothing to loose and yes if you want carpeting for your boot because it is worn out,a good place to start. Same material used for all the NP DB cars as well.
    jay
    10 May 2013 at 06:17 #50157
    many thanks for the replys
    i will do as you sugest and call lincoln scott in lewes
    10 May 2013 at 15:01 #50158
    If he does have any original type carpet would you mind letting me know. Most of mine is fine but I don’t want two different types of carpet – I think black pile is the only other alternative I can find. I’ve actually drawn up every bit of carpet both in the boot and cabin so I can have it remade – I know how to have fun!
    14 May 2013 at 11:17 #50162
    I may have sourced a good match for the original carpet, I’m going to look at it tomorrow. if it is right I’ll probably have enough left over for what you need. I’ll let you know…
    15 May 2013 at 21:03 #50163
    I bought some new boot carpet today – it looks a closer match IRL – the photo in the link shows the original on top of the new…
    Photo here
    16 May 2013 at 21:46 #50167
    That is a very good match – well done!
    Perhaps you could share the source with us. In my boot, it is the large floor mat which suffered when front brake caliper fluid split on it during storage.
    17 May 2013 at 08:19 #50168
    Hi, it can be bought here (look at Cavendish – jet black is available but not shown) – I went to a Diamond Floors showroom to see it as it’s not very far away… I’m replacing all of my boot carpet so the difference in blackness and texture won’t matter…
    17 May 2013 at 13:26 #50169
    Thanks for the contact, greatly appreciated.
    Since I only need the boot carpet floor section piece replacing – actually, a 3 inch x 3 inch section from this, I will wait until I find a closer match, or maybe have the carpet repaired locally.
    17 May 2013 at 15:11 #50170
    Quite a bit of my old carpet is good so you could have some of that, then you would have a perfect match…
    17 May 2013 at 15:22 #50171
    Thank you !
Viewing 13 posts - 1 through 13 (of 13 total)
